Thermostat that calls 2 stages of heat independently?
I understand that most thermostats with 2 stages of heat try stage 1 first and then activate stage 2 if needed, leaving stage 1 on.
Is it possible to find a thermostat that has 2 stages of heat but which also disables stage 1 if stage 2 is activated?
    Jamie Hall Member Posts: 27,396
    There are some fairly simple ways to do that with a relay...
    JUGHNESuperTechSolid_Fuel_Man
  • Steamback
    Steamback Member Posts: 39
    Thanks, Jamie. That makes sense for sure...
  • ratio
    ratio Member Posts: 4,243
    I'm guessing two different heat sources? What are you trying to accomplish?
