Interesting!
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Rich_49
  • Solid_Fuel_Man
    I wonder how it compares cost-wise to the components it replaces. There's an obvious labor savings to take into account as well.
  • kcopp
    kcopp Member Posts: 4,630
    What happens when the expansion loses its charge? That's a whole lot more work to replace that......
  • unclejohn
    unclejohn Member Posts: 1,833
    Like when the built the spark igniter onto the gas valve.
    SuperTech
  • Big Ed_4
    Big Ed_4 Member Posts: 3,363
    Hmmmm. Where is the point of no pressure change now ?
  • kcopp
    I looked at the website.
    They say its replaceable....
    Definitely is thinking outside of the box.
    http://www.calefactio.com/products/non-code-expansion-tanks/heating/the-one
  • Eastman
    Eastman Member Posts: 968
    ...needs more functions-in-one.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Same place it's always been Ed.
    ME
    CanuckerIronmanGordy
  • Gordy
    Gordy Member Posts: 9,546
    Inovatve idea. However I think modular, and if you lose the bladder the hole thing needs replaced. So the cost of it verses separate components comes to the labor cost savings. That, and someone who doesn’t have the ability to properly place the individual components in the system. This makes it easy. Pump away on the return, or pump away on the supply.
    It does take away the ability to pump away on the return which most mod/cons prefer, and have the air removal on the supply where fluid is the hottest to facilitate optimum air removal.
    Then throw in the hydraulic separators which have become the multi purpose tool in the system.
    hot_rod Member Posts: 26,592
    Clever idea.
    It must have 4 penetrations into the bladder, for the valve, connections and air vent?
    And for mod cons that require that you pump into the boiler, as Gordy mentioned?
  • Gordy
    KInda found oriented to the plumber statement Humorous, was that trying to say something.........
    Solid_Fuel_Man
  • Harvey Ramer
    It's certainly not a catch-all, but it could be a useful product to have available.
    Gordy
    As long as repair parts are still available in 5- 10 years from now?
    A rebuildable device with no parts down the road is ??
    Zman
  • Paul48
    Paul48 Member Posts: 4,469
    The name seems like they're trying to ride someone's coat-tails......no?
    Gordy
  • Gordy
    I certainly think it could clean up certain installs. Again know where, and when to use it.
    Back to modular components. I guess the way would be to have some in the truck, and swap out. Then rebuild at your leisure rather than on site. Seems the tank with multiple bladder penetrations as @Hotrod pointed out is the most vulnerable.
    Only two tank volumes also..
  • Solid_Fuel_Man
    Plummmmmmmmers..........
  • Harvey Ramer
    That's true. There's always a certain degree of risk when taking on a new product. Some stick and some are a flash in the pan.
    Never the less, it is good to see this type of creative innovation in hydronics.
    The iso flanges with the pressure gauges and the stainless flow-thru design DHW expansion tank are clever products that they manufacturer also.
    The biggest challenge for these small "boutique" manufacturers is getting into the market at a level that can sustain the business and turn a profit.
    Also the chance someone else knocks it off and drops the price.
