How long does it take for water to return from radiator once heating is turned off?
Aditya
Member Posts: 1
in Gas Heating
I have steam heat. I switched on the boiler. Then I let the radiators heat. Then I switched the heat off. Waiting now for all the water to recede. How long should I wait?
well you shouldn't have to wait,
the water may fall an inch or so in the sight glass, but it should always still be there in the sight glass.
Sounds like you have issues there.
What boiler pressure are you set for?
and what pressure do you see?
Post pictures of the Pressuretrol, and of the sight glass,
and of the boiler showing the pipes above to the ceiling.
Are the radiators one pipe or two?known to beat dead horses0 -
You're waiting for the water to "recede" from where?0
There really isn’t much condensate generated. 1 gallon is 8300btu. That’s about 3:00 of running for a 150k boiler. So 0.3gpm. A small stream from a faucet.0
If you really mean recede -- presumably from some radiator or other -- there really never should be any water to speak of there in the first place. There may be some in the bottom of the radiator -- depends on how it is built -- but that will stay put. As @mikeg2015 noted, steam heat doesn't generate much water.
If instead you mean watching the water level in the site glass of the boiler, it could easily be a minute or two after the boiler shuts off for it to recover to its original level after the pressure drops to zero. Shouldn't be a whole lot more than that, though.Br. Jamie, osb
- 128 Chimneys & Flues
