replacement for Nesbitt water coil?
ratio
ratio Member Posts: 4,247
Any suggestions for a replacement for a Nesbitt model # 572 NR 8A hydronic cabinet heater coil? 4' x 8" x 4" (finned area, hairpins & headers not included) coil, 8 pass, ¾" tappings. From a parochial school, c. 1970-1980.
    EBEBRATT-Ed Member Posts: 20,261
    Are you looking to replace the coil in the existing cab heater or replace the entire unit.
    American Air Filter I think bought Nesbitt you can google and find a rep.
    If you replace the entire unit Majic Air may have a close match.
    If you just need a coil for the old unit and coil mfg can make a replacement. depends on your time frame what you want to do.
    Google: Nation wide coils or The coil company are examples
  • ratio
    Thanks, I'll look into them. Ideally I'd just replace the coil, the customer really can't afford to replace the whole unit.
    I'll check into getting one manufactured too, but that sounds expensive.
  • JUGHNE
    JUGHNE Member Posts: 11,562
    How many leaks? Is it possible to solder?
    Many coils that old had enough material to solder holes shut.
  • Plumboe
    Plumboe Member Posts: 3
    Hi: I would give this Company a call. Dalsco HVAC Sales 166 Ridgedale Ave, Morristown NJ 07960. This Company is a Nesbit Dealer. Good Luck!
  • ratio
    Here's what I've got now...
    I seem to still have a leak under the steel bracket. I'm going to try and cut down to it, but it's getting pretty comical
    @ ratio, if you call a coil co and give them:
    Fins/inch
    pipe connection sizes
    length
    width
    thickness
    size (diameter) and number of tubes etc
    They should have enough information to give you a quote
    Looks like that thing can't take much more patching
