Gas orifice design
ChrisJ
ChrisJ Member Posts: 17,357
edited December 2017 in THE MAIN WALL
Hi all.
I would ask @Tim McElwain but I think he's got more important things to deal with at the moment.
Gas orifice drill sizes are readily available but what I can't find is the length of the orifice. As in fine I need a #31 drill size but how deep should it be at that dimension before going larger?
We made this where I work to convert an outdoor lpg hurricane burner to NG.
    EBEBRATT-Ed Member Posts: 20,150
    I would think you would drill it all the way through. Are you concerned with the orifice being long that the #31 will be too restrictive at that length??
    most orifice's are about the size of an 1/8 pipe plug so I guess if it's a long orifice drill it oversize and leave a 1/4" drilled at #31.
    Just guessing. Anyway to clock the meter after drilling to check it out?
  • ChrisJ
    Yeah that's what I'm concerned about. I'm hoping there's engineering data out there for it.
    I'm hoping to fire it up this weekend to see how it works.
  • Bob Harper
    Bob Harper Member Posts: 1,158
    There are charts in NFPA 54' showing BTU flow rates for a given orifice at a given pressure for a given gas.
  • ChrisJ
    Yes.
    And none of them specify how long the orifice is, only it's diameter.
  • ChrisJ
    @captainco Any thoughts on the length of an orifice? Is there a design spec for it?
    Like I said I need a #31 orifice diameter but how long? It's got to have an effect to an extent unless anything 1/2" to 1/16 is considered fine
  • ratio
    ratio Member Posts: 4,229
    It looks like as thin as possible yet able to withstand the forces applied: see http://www.springer.com/cda/content/document/cda_downloaddocument/9783319168791-c2.pdf?SGWID=0-0-45-1505283-p177306192
    See § 2.5.5 in particular.
    Until you end up with what's basically as piece of pipe, I doubt that it matters much for our application.
    ChrisJ
