Small rads upstairs
adasilva
Member Posts: 144
Single pipe system with two small rad upstairs with the vents located on the top of the radiator due to the fact the main plug being in the way of turning the vents out to remove them. With them up top the rads only heat so far as the air keeps the steam out due to not venting properly! With all that in consideration can I just small pipe a new vent to lower the location of it & have the same result as having it in the lower port of the radiator? I do have new vents but did not install due to the large plug in the way of the vent. I am kid free this weekend and would like to do this before she is here next weekend (if this is a feasible plan).
Thoughts??
Thoughts??
Doesn't the vent belong in the tapping that is 1/4 the way up from the bottom of the radiator?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg1 -
@Brewbeer it does but whoever installed them didn't know better and now I need to remedy the issue. That's why I asked if I pipes the vent from the upper hole and down to where is should be would do the trick? The plug where the vent should be isn't budging and I don't want to break it.0
It might be worth a try -- but I think (just my opinion, no actual experience) that it really wouldn't make a difference, since it seems to me that what counts is where the outlet from the radiator is.Br. Jamie, osb
I dont think piping as you suggested will work. The plug in the correct tapping should be drilled out and extracted in pieces if necessary.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
OK one last question. Is there any reason to NOT use a brass plug to replace the vent up top after I drill out the old plug and install the new vent? Seems that finding the plug in cast iron or even steel is tricky at this point.....0
I agree with @Boiler wrestler install a new vent in the lower tapping. After the heating season you can remove the old vent. You can take the plug out and install a countersunk plug that won't stick out so far or just cut the old vent off so you can turn out what's left and install an 1/8 pipe plug1
So I had good luck with one of these rads and the plug just backed out with no issues at all. New vent installed and waiting for it all to heat up now!1
