Steaming at 1am
Danny Scully
Member Posts: 1,425
I eluded to this job last week (which took until 1am to get steaming), and here’s the finished project. Job details: Burnham Independence with 3” drop header, power venting added, separation of steam mains connected above the water line, VXT, condensate zone for turbo max instantaneous indirect water heater.
2
Nice job Dan.
Question on the Turbo Max. Is there a domestic relief valve and thermostatic mixing valve somewhere? Can't see the tank too well in the pic.
I used to install an 1 1/4 x 3/4 x 3/4 tee and a 3/4 street x female on top of the run for the domestic relief.0 -
Very nice, lotta work for one day!!DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......-1 -
Yes @HVACNUT, it was hard to get a decent pic over there in the corner. I used a Caleffi mixing valve. I reduced from 1-1/4 to 3/4, then came off the bull of a 3/4 tee for the mixing valve and the run on top for the relief valve.-1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
