Vapor Restoration
Dan Foley
Dan Foley Member Posts: 1,268
Poppy and his crew restored this vapor system in a 1916 rowhouse in Columbia Heights, DC. Only two of the graduated inlet valves remained and neither worked.
The Peerless boiler is fairly new. While not perfect, it is piped better than most we see. We added a skim port and installed a Vapor-Stat set to 8 oz.
There were no steam traps as the original system relied on low pressure and graduated inlet valves to keep live steam out of the returns.
  • Dan Foley
    edited November 2017
    We elected to go with orifice plates, rather than traps, to mimic the original graduated valves. At low pressure, it will not allow more steam to pass than the radiator can condense.
    Poppy drilled the copper plates with a specific size bit to match the EDR of the radiator.
    RomanGK_26986764589
  • Dan Foley
    The owner had these Pierce Butler radiators hot dipped, sand blasted and re-finished.
    RomanGK_26986764589kcopp
    Steamhead Member Posts: 18,205
    Pierce made the original valves too. Most suppliers offered graduated valves back then.
    Did "Chem Strip" do the refinishing? This looks like their work.
    Consulting
  • Dan Foley
    Frank, you have a good eye. Yes, Chem Strip did the re-finish work.
    Thought so. Nice work! Bet this system works perfectly now.
    Consulting
    Dan Foley
  • BobC
    BobC Member Posts: 5,539
    Beautiful radiators, with those orifice plates the system will now work the way it was designed.
    Bob
    3PSI gauge
    Dan Foley
  • jumper
    jumper Member Posts: 2,501
    I wonder how well TRVs would work on these old systems? Can steam TRVs be set so that they don't close entirely?
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Yes @jumper, you can’t close trvs completely.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Do you mean TRV's with the orifices installed?
    Was there a reason for the dead men to pipe in and out of the same end of the rad?
    Did you size the orifices for 80% of the EDR at 8 ozs? Just curious. When I drill orifices I put them in a union with a nipple attached, that holds them pretty well. I order all of them with an 1/8" pilot hole predrilled also.
    Dan Foley
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    I want to bronze Poppy's hands. They're beautiful.
    Retired and loving it.
    Dan FoleySeanBeans
  • gerry gill
    gerry gill Member Posts: 3,083
    nice job, beautiful radiators.
    gwgillplumbingandheating.com
    Dan Foley
  • Ironman
    Ironman Member Posts: 7,857
    Very nice!
    Bob Boan
    Dan Foley
  • Dan Foley
    @ JUGHNE
    I have never combined TRV's with orifice plates but I don't see why it would not work.
    I don't know why the dead men piped the radiators on the same side. I have seen them piped both ways.
    I like your idea of using a union and nipples as a jig to line up the bit.
    Where do you get pre-drilled blanks? I get mine from Tunstall but they are not drilled.
  • Fred
    Fred Member Posts: 8,542
    I think some of those radiators that are piped on the same side have a tube in them that runs across the inside bottom of the radiator to the other end. Just a thought.
  • Dan Foley
    @ Fred. Yes, I have seen that on hot water radiators but not on steam.
  • JUGHNE
    Dan Foley, I ordered the orifices with 1/8" drilled, they are from Tunstall.
    Were you able to buy direct from Tunstall?
