shutoff valve for gas fireplace
Hello,
We are selling a house with a gas fireplace. there IS a shutoff valve for the fireplace about 20 feet from the actual fireplace. Buyers had the house inspected and are asking for a shutoff valve to be installed. I asked the realtor if they found the one 20 feet away (in a utility room), he wasn't sure. He is thinking there may be code requiring it to be closer to the actual fireplace. Is there such a code? If not, I'll just point out where the shutoff valve is.
Thank You
  • Leon82
    Leon82 Posts: 681
    A Google search says the irc calls for within 6 feet of the appliance
  • Leon82
    Leon82 Posts: 681
    edited November 2017
    It's possible your local inspector looked over it
    It's also possible you are on a different code than the irc. You could always call your building Dept and find out. But that can also open a can of worms if there was never a permit for it
    Jamie Hall Posts: 28,048
    Sometimes, if you really want to sell and the price is right, the easiest thing to do is to say OK and just install the valve...
    EBEBRATT-Ed Posts: 21,422
    20' is not code. Shut off must be closer than that. Check with local inspector or if you don't want to tip him off call a fireplace installer to find out what's required in your area
  • Henry
    Henry Posts: 998
    The valve can be further away if it is identified as for the fireplace
  • National Fuel gas code states the shut off must be within 6 feet of the appliance. All the fireplace inserts or unvented appliances I have installed I always put a shut off as close to the equipment as possible with easy access in the event of an emergency.
    Henry
