Can I utilize one outdoor temp sensor for 2 controls
yourefree
Member Posts: 4
Hi. I have a navien combi boiler and I am going to add the outdoor reset sensor to improve efficiency of the radiant floor heating system which warms the basement slab. My question is I already have a 10k ohm sensor that works with a carrier furnace to control the humidifier during the winter, can I tie the Navien boiler wire into that same sensor - it is the correct spec but I haven't been able to find out if it will cause an issue with the Navien or the Humidifier control. Wondering if anyone has tried this. Trying to avoid having to install a second sensor system which would involve more holes in the wall. Thanks
HBX Controls has a wireless outdoor sensor that allows up to 5 devices to one outdoor sensor. You would need two base units and one sensor.
http://www.hbxcontrols.com/wav-0110.php0 -
That's neat! I've been wanting access to a product like this for years.0 -
That is a really nice product much needed on a bunch of projects I have going on.0
Thanks for the advice I will buy a new sensor system for the Navien, Up until now I have had it set at a constant 117 degrees per the engineer who designed the system. I'd like to make use of the outdoor temp feature so it adjusts the water temp accordingly.0
- 125 Chimneys & Flues
