Small steam replacement
Dave0176
Member Posts: 1,178
Elmwood Park NJ owner said the boiler wouldn’t hold water and the floor around the boiler was always wet, I indeed found the boiler leaking due to rot around the return. The old boiler a Crown rebadged Dunkirk had no header and was oversized. So in went a Union Steam GSA-75000.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
2
Beautiful install as always @Dave01760
Nice one @Dave0176!New England SteamWorks
newenglandsteamworks.com0 -
And of course, the Dunkirk had a 2-1/2x2 bushing in the steam outlet. So much for reading instructions.
Nice job, and I'll bet the system runs much better now. Is that boiler a re-badged Weil-McLain?All Steamed Up, Inc.
Consulting0 -
@Steamhead yes It is. And yes it’s pretty common around here to find all the Dunkirks piped this way, hahaha, actually most use 2” copper.Steamhead said:And of course, the Dunkirk had a 2-1/2x2 bushing in the steam outlet. So much for reading instructions.
Nice job, and I'll bet the system runs much better now. Is that boiler a re-badged Weil-McLain?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
nice!!0
@SeanBeans yes I asked the customer if she wanted an automatic water feed, but she said no, she checks on the boiler often. That’s is a new ball valve on the feed I used a compression fitting valve as it wouldn’t stop leaking.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
cool, thanks.0
In 70 years I've never liven in a house with an auto fill, checking the boiler a few times a week is not a hardship. Ignoring a boiler is easy, paying to replace a neglected one is not easy.
3PSI gauge0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
