Snow Melt
I've installed two, both electric, in the past decade or so. One for the phone company, one for the local library system (whose income exceeds many country's GNP). I've seen a half-dozen or so more; all entities with buckets of $$$. So, I guess not very common.
If I ever get a chance to pour a new sidewalk out in front of the homestead, it'll have PEX in it. I would dearly like to never have to shovel snow again!
I visited the most wonderful city of Sapporo in Japan's most northern Hokkaido island in the summer of 1997... We were told the city has all their DT sidewalks heated. After living in northern Michigan for 2 years prior, I thought it was a joke. It wasn't.
https://www.theatlantic.com/international/archive/2016/01/japan-snow-country/426738/
Many hospital ER entrances and ramps might have it.
We simply have a heated ER garage to drive into. All ambulances have a remote for the door opener.0 -
New Casino being built in MA. has hot water snow melt on the exposed parking garage ramps0
The demand is slowing from my perspective in Greenwich CT area. Last one I did was about 5 yrs ago, 10, 000 sq ft. 3- TT399's; somewhere around a million BTU.0
Thanks for The responses0
Guess we know who is paying for that...lolEBEBRATT-Ed said:New Casino being built in MA. has hot water snow melt on the exposed parking garage ramps
1 -
When I worked at the airlines, Eastern Airlines in Boston our multi bay airplane hanger was all floor heated....I was a line mechanic so I never benefited from it...but the ramps leading into it were heated as well so when towing in a broke down airliner it did help...0
Did a few over the years. Went on probably close to 40 look sees, gave 10 or 12 serious quotes. Less than 5 of them actually had it done. It's not that common here in New York. Mad Dog1
Didn't you do your drive way, and try some solar harvesting in summer with it Mad Dog?0
Ahhh...you remember! The solar driveway.....Laid the grid, did the driveway and soon after the economy nose-dived. Never again had "disposable income" like that to lay out after that for the tanks, controls at al. If the next owner or one of the kids want snowmelt or to tackle it, IT'S ALL THERES. Jr. Is training to be an engineer, so we'll see. Mad Dog2
Had a few in Boulder, CO, but then the eco nuts made a rule that for any snowmelt system the total expected load of the installed system had to be offset by some kind of renewable energy kw for kw. Looked at doing one on a driveway that was about a mile long and full of switchbacks, steep as hell, almost impossible to plow, and dangerous with dropoffs close to 50' for most of it. Did the calcs and she would have had to put in a PV field roughly 1/2 the size of a football field to offset the snowmelt system.
We didn't do that one....1 -
I would never forget anything you have discussed, or accomplished Mad Dog.
3 -
The solar driveway...that sounds like a really good idea! I just had a new garage built...in addition to insulation and tubing in the slab, we also laid tubing in the garage apron slab, the walkway from the house to the garage, and the sidewalk from the front porch to the city sidewalk is planned for spring...all with 2.5" foam board beneath and 3" up the sides (about an inch below the level of the finished yard).
I'm intending to *eventually* install solar collectors on the garage roof (solar-south-facing by design) to help offset operating costs. I currently have 500 watts of solar up there with a standalone electric system in the garage. Time & money, that's all it takes - ha. Sigh.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
The problem with Solar Snowmelt is getting the sun to shine when it is snowing out.
Albert Einstein0 -
Agreed...it's primary purpose will be to heat the garage and a storage tank. Someday.Ford Master Technician, "Tinkerer of Terror"
Exactly, Gordy. Tanks. And be able to switch over to snowmelt . Mad Dog1
In the Denver market it was one of my bread and butter offerings. I have done at least 50 to 60 for my various contractors. The last one I designed and installed was 7,500 square feet for a Private guest house in Castle Pines Co. The boiler was a Viessmann CM2311 1.1 million btuh boiler. Wound up bieng a very nice system with the exception of the start up of the boiler. That part was a pia.
Fighting the Green Weenies of Boulder (and Aspen) Colorado. Aspen (Carbon County specifically) started this alleged war on snowmelt many years ago. It was thought to be an egregious waste of natural resources. Whatever... The people of Aspen can afford to burn money on their driveways to keep them free of snow and ice, but then the Greenies would have a fit over the smoke and fly ash. I think that everyone is missing the boat with snowmelt. My back of the envelope calculations show that we could "harvest" more energy from a typical properly operated snowmelt system then the snowmelt system uses on an annual basis. And we can do it with off shelf technology. It would require some means of storage of the harvested energy (like GSHP, or Thermal Battery Storage systems). If we harvested and used every solar btu that fell on the active surfaces of a typical snowmelt system, we could put a HUGE dent in the fossil fuels we use on a daily basis.
Ideally, there would be a load (think restaurant) to accept the harvested energy, but not necessarily.
Ya'll need to start thinking outside the proverbial box. Heatboy (the ORIGINAL) did Mario Andretti's driveway many years ago, and tied it into his Olympic sized swimming pool, and completely eliminated natural gas consumption associated with the pool. They now have PEX tubing which is designed for exposure to higher adn constant exposure to oxidants (chlorine) that can be used for direct heating of pool water. Think radiant cooled decks around the swimming pool, harvesting FREE solar radiation. This is not new technology. We just need to apply what we already know.
As it pertains to Boulder, tell them that you want to use a wood fired gasification boiler, that will use the Beetle Kill pine. That's about as green as it gets, and they have to accept that because it is considered an "Alternative Energy". With the pellet burners of today, it could be set up such that it would be nearly free of the end users services, with the exception of hauling ash and paying and ordering pellets.
ME0 -
Have to smile, Mark. I remember in the 60's Aspen was just a sleepy little ski town. When they began developing it the "Aspen Underground" would blow up the condos. That was of course before Texas bought Aspen.0
ME mentioned:
This has been the challenge for solar thermal since day one, still no efficient affordable answers to storage. And with fossil fuel so cheap, not many are looking for storage break throughs.
The thermal energy from a concrete or asphalt surface would be fairly low grade, maybe 100F harvestable from the bottom of a slab or asphalt. Certainly good for DHW pre-heat, depending on how many degrees you loose before you have a load to use it on, but not a lot of 90- 100F SWT hydronic systems out there.
Over the years we have tried all sorts of thermal storage in rock beds, sand layers, bore holes, geo loop fields, water, brine, phase change materials, etc. The cost and space required to store 10's of thousands of gallons for winter use. The loads are still to lopsided to make seasonal thermal storage feasible.
Worldwide there are some solar and bio district systems in design or under contract, mainly in countries with fuel costs 3 or 4 times what we pay, and driven by the populations desire to spend $$ to get off fossil fuels.Bob "hot rod" Rohr
Living the hydronic dream1 -
See Photos....Here is a set of under pavement coils (in line with tire tracks). Sloped driveway is 140 feet long. Uses about 150 amps but runs only 30 minutes for complete melting process. Dan Foss makes the cable. Purchased in Salt Lake City from Warmzone and installed on my driveway in Carlisle, Massachusetts. Great luck since 2008. This image is 2016. All GOOD! Also, did my roof valley with a automatic low voltage mat shown in last image. Product is By Steep.0
We use our hydronic product to "harvest" heat from driveways and patios often. We utilize a panel system instead of a PEX system which allows for greater heat transfer rates in both snowmelting and harvesting mode. The savings from harvesting this heat in the summer often offsets the cost of snowmelting in the winter. We have also found that by harvesting heat has a considerable cooling effect on the paved surface, sometimes up to a 50 degree reduction.0
What is your hydronic product?0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
