Poly pipe in B vent
Zman
Zman Member Posts: 7,611
I am looking at a project that involves using 2-4" condensing boiler flues in an existing 14" B vent.
We would like to be able to sleeve the 60' vertical pipe without having to cut into the pipe to provide support. I have seen products designed for smaller single pipe applications.
I am wondering what is available for this larger application.
Albert Einstein
  • Dan Foley
    Dan Foley Member Posts: 1,268
    @ Zman
    We used this product on a commercial project last fall. We lined a 50' masonry chimney with (2) 4" PPS flexible liners.
  • Dan Foley
    Pictures did not post.
  • Zman
    edited July 2017
    Thanks Dan,
    I like how that came out.
    I am concerned that the 2 round pipes within the bigger pipes will want to move around.I am also wondering how the code authorities will rule on it.
    What do you think of this detail?
    It would only be anchored hard at the bottom, the rest could go up and down with ease. This would be using hard pipe.
    Albert Einstein
  • Dan Foley
    The Centrotherm kit has spacers that keep the flexible PPS centered in the existing flue.
    I too was concerned with the inspectors. I had drawings prepared by Centrotherm as well as the boiler manufacturer. It was not an issue as the inspector approved the installation.
    Zmankcopp
