Poly pipe in B vent
Zman
Member Posts: 7,569
I am looking at a project that involves using 2-4" condensing boiler flues in an existing 14" B vent.
We would like to be able to sleeve the 60' vertical pipe without having to cut into the pipe to provide support. I have seen products designed for smaller single pipe applications.
I am wondering what is available for this larger application.
Albert Einstein
Albert Einstein
@ Zman
We used this product on a commercial project last fall. We lined a 50' masonry chimney with (2) 4" PPS flexible liners.0 -
Thanks Dan,
I like how that came out.
I am concerned that the 2 round pipes within the bigger pipes will want to move around.I am also wondering how the code authorities will rule on it.
What do you think of this detail?
It would only be anchored hard at the bottom, the rest could go up and down with ease. This would be using hard pipe."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
