Is my plumbing company screwing me?
A plumbing company in the bay area recently told me they would pressure test my three small steam radiators at a rate of $195/hour. They said it would take maybe 1 - 2 hours.
On the day of the test, two guys showed up separately. The first guy said the second guy had just stopped by to help him get the radiators on the dolly and wasn't going to do any of the work. The second guy confirmed and said that's why he had parked blocking traffic - because he was leaving.
To do the tests, the guy used the hose downstairs at my building. Importantly, there is only one hose bib downstairs for him to use. It is the only water source down there.
It took an hour an five minutes total to do all three tests.
The bill I got is for $630. Yes. I am being billed for two guys for an hour and a half each, including travel time, plus taxes. They're telling me both guys were present the whole time (despite what the guys told me) and that both were working the whole time. They are also telling me that if only one guy had been sent, it would have taken a lot longer than an hour and five minutes.
This seems like a bunch of BS to me. If theres only one hose to hook up to a radiator, how could both guys have been testing the radiators at the same time?
Also, isn't twenty minutes per radiator about right?
Any help or thoughts you guys have about this would be greatly appreciated. Thanks!
I'm sorry if this disagrees with your thoughts but if both employees were there then someone has to pay for their time. It would have taken longer with one person that is true. They did say 1-2 hours to do the job. When you say it took an 1 hour and 5 min. Was that timed from the time they showed up at your home , and until the time they left your home? 5 min in to the next 1/2 hour counts as 1/2 hour as far as paying his employees. They do not get paid in 1 minute intervals.
Are you sure you have steam heat, and not hot water? Wondering why they didn't test using air. Which would not matter time wise, and would not hurt anything. Just less mess. You still have to pressurize the radiator, and wait a while to see if it holds pressure.0 -
As @Gordy says, the charges don't seem out of line for the time required.
However, did you ask them to pressure test the radiators? Or did they suggest it? If it is steam, they should not have been pressure tested. Leak tested, at 2 psi, perhaps. But pressure tested? No.Br. Jamie, osb
I will also note that we do not discuss pricing. That being said I have no idea if the rate you posted is customary rate for your region. So as far as the hourly charge in the Bay Area it may be right, but I'm not from there. Sounds about right though.
You must consider what goes into an employees wage package, and the cost of the owner running a business.
Insurance
Training
Workers comp
Unemployment
Etc.0 -
Although I agree with the above, I think you have a right to be annoyed. I would ask for some money back.
1. You should be charged for the second guy at a helpers rate.
2. When they bid the job (hopefully in writing), they knew they needed a plumber and a helper, and should've told you that and reflected that in a bid. The plumber's rate and travel time aren't off the mark, but if the contractor's shop is nearby, there shouldn't be much of a charge. If he is far away, he should've factored that into the bid. Personally, I wouldn't charge travel time if I happened to be way out in the suburbs on my last job. I would only calculate travel time from my shop.
3. I think the bill was padded to make up for a slow day.There was an error rendering this rich post.
1 -
It's hard to find good steam experts here in the Bay Area. I'm sure you had to call around to find anyone that would do that kind of work.
Curious as to why you wanted them pressure tested. Did you just buy the house and wanted to make sure none of them leaked?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Very very unusual to be called to pressure test a radiator....Curious as to why....Few more details and some pictures may answer the curisoity0
I personally charge a minimum of 1 1/2 hours. I can not judge another rate as I am not in your area. I am curious why the test.Cost is what you spend , value is what you get.
cell # 413-841-6726
So you were misled into approving the work by being given an estimate which they then failed to honor and on top of it you were lied to by the workers when you questioned why there were two of them. I would have sent them packing right away but now that you have the bill I'd "negotiate" with the company to get them to honor their estimate. If they needed to send two employees to do the job they should have told you up front it was going to be 2X the hourly rate. Unfortunately sending "extra" workers is a common practice to enable charging more and I've canceled more than one T&M job because of it.3
@gschallert I think you are making presumptions beyond what the op has stated in the original post. Until it is determined if there was a concrete estimate other than the 1-2 hours to perform testing, and the 195.00 per MH. I don't think bashing the contractor is warranted....yet. They performed the work in the estimated time frame, and as to whether it was told to the owner there would be 1or 2 people doing the work we just don't know, other than the employee saying what he said.
Is it really any different if one person takes 3 hours, or 2 people take 11/2 hours. Maybe they wanted to be sure that the job was done in the estimated time frame.
As for how long it took to test 3 radiators. Do we know the terrain of the job? We're they on the 3rd floor? Hard to remove, and replace?
Did someone look at the job, and someone else perform the work?
I'm not condemning, or supporting without more information.0 -
This. What was the driver behind the pressure test? I can't imagine why (on steam) anyone would want to do it.Jamie Hall said:
If it was their idea to test I would suggest that would be the red flag for me as anyone that knows steam knows the pressure is extremely low in these systems and testing rads shouldn't be needed (IMHO). If it was your idea, no matter what amount of money it was wasted.
I will reiterate we don't discuss pricing on this site. You could have mentioned how many hours they billed and left the dollars out.
Still don't know the driver behind this...and I agree with Gordy...Reason for test may be they a converting to hot water and in that case it's a good idea to accomplish a hydrostatic test..at this point it's anybody's guess...Owner of site states no price talking, so I won't...Really need feed back from the op as well as the plumber involved...as to what was accomplished...Kinda don't think that will happen...There are proper channels to go thru if one and or the other has issues...Bitching about cost here should get you nowhere...jmoKC_Jones said:
@Gordy, no presumptions required, the OP stated the following:Gordy said:@gschallert I think you are making presumptions beyond what the op has stated in the original post. Until it is determined if there was a concrete estimate other than the 1-2 hours to perform testing, and the 195.00 per MH. I don't think bashing the contractor is warranted....yet.
1) They were told the job would take 1-2 hours @ specified hourly rate. If the plumbing company knew it was going to take two employees 1-2 hours an ethical company would have informed the OP the job would require 3-4 labor hours @ specified hourly rate.
2) When OP questioned both workers who showed up they said only the one would be staying and yet the OP was billed for both and told the opposite of what the workers said. Somebody was lying, doesn't really matter whether it was the workers who showed up or the company they work for, the OP was lied to.
@KristinaL, see #8 on this list: https://www.moneytalksnews.com/10-sneaky-plumbers-tricks-the-trade/2/2 -
Curious as to why you wanted them pressure tested. Did you just buy the house and wanted to make sure none of them leaked?"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
i used to live in California some 20+ years ago. Cost of living was stupid then...i can only imagine what it is to run a business there today..i think our workers comp was 20% back then..crazy numbers..i cant believe they stay in business out there at 195 an hour..gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.2 -
Got to say I totally agree...with your thinking....there are always two sides to every story....Give the company a chance to speak...prior to forming an opinion...He may not know he has been spoken about here on this site...gerry gill said:i used to live in California some 20+ years ago. Cost of living was stupid then...i can only imagine what it is to run a business there today..i think our workers comp was 20% back then..crazy numbers..i cant believe they stay in business out there at 195 an hour..
Anyone notice the OP hasn't been back?
Honest question. If the company said one thing and done the other, or charged for a tech that wasn't there, don't pay. I once had 3 electricians work about 6 hours on the building I manage. I knew hourly rate, so no problem. Bill comes, they listed 8 hours each. Granted, they could have dragged it out, but 18 manhours was fair for the amount of work, and they clearly didn't rush the job. I called and complained, gave times they showed up and when they left, nicely and politely. They took the 6 manhours off the bill and apologized.
Bigger issue is that more and more the middle class is being squeezed, that living standards are falling (doing more with less), and that the wealth is concentrating at the top. That leaves a whole lot of people who pay their weekly (or more) of after tax wages for one day of tech in the house. But, that's politics, right?
Now, how anyone affords to live in the big metropolitan areas is still an enigma to me. West coast? Get outta here....1 -
The first few responses did not try to burn the plumber at the stake. Therefore I believe the original poster had no incentive to come back.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
I do believe you are exactly right...I believe the trap was being set...jmoCharlie from wmass said:The first few responses did not try to burn the plumber at the stake. Therefore I believe the original poster had no incentive to come back.
Yet another benefit of flat rate pricing, no surprises.0
Oh gee honey I think it's time to get our radiators pressure tested...yes Alice your correct...They are reaching 100 years old...Lets skip our next planned vacation, and get them done...I have long suspected they have issues...0
I deal with many people who are disappointed that I do not ask for capital punishment when I see a bad installation. That is experience not clairvoyanceCost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating3 -
I wonder how many accounts are there on HeatingHelp with just 1 post. Do they eventually get deleted?0
@KristinaL
How did this work out?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
