Stadler PH 24 zone valve power head
Looking for a source for PH 24 power head. All information I have gathered indicates they are no longer in production. Is there a replacement? Does anyone have old stock? Help, please.------------------gjkris
  • newagedawn
    newagedawn Posts: 585
    i never heard of those, might have to install a new one, body and power head, what size pipe?
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
    hot_rod Posts: 28,529
    do you have a pic? It could be a private labeled part from another manufacturer.
  • gjkris
    gjkris Posts: 2
    I have a pic. will try to
    upload
  • Ironman
    Ironman Posts: 7,965
    This should work to replace it:
    https://www.google.com/search?q=rehau+actuator+24v&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari#imgrc=BOPftt3z2Y3eKM:
    Caleffi may work also. Hot rod can verify that.
    Bob Boan
    Did it come out of that RTI box behind it?
    It is a German valve, so not one that Caleffi manufactured.
    Sometimes inside you may find a manufacturers logo or name.
    What you will find it the threads are common across the brands, so most any actuator will attach.
    The small difference will be the pin length on the valve part, and the stroke length of the actuator.
    What can happen if you don't check is the valve can be held partially open when it is powered off, or it may not stroke far enough to fully open.
    Really need to check that tolerance if you switch brands.
    In some cases we send an adaptor ring when the Caleffi brand is used on OEM manifolds..
  • JeffM
    JeffM Posts: 185
    Stadler is now owned by Viega. There is a new powerhead available from Viega that will fit by using an adapter ring. Call Viega tech support and explain what you're looking for to get part numbers. 800-976-9819
  • Viega part number 15065 will allow you to use a viega powerhead on those old brass Stadler manifolds.
