Hyrdropulse A150
stillrunninga150
Member Posts: 1
New here to the forum as far as being a member but I've search forum many times before.
Not sure if this is where I need to be asking this question, if not please tell me where I should be.
I've got a 1980s Hydropulse A150 that I am in desperate need of a repair manual. If anyone has one or can point me in the right direction to obtain one it would be greatly appreciated.
Thanks,
Tom
Thanks,
Tom
@Tim McElwain is likely to have what you are looking for.
I should be noted that no boiler will last forever. You may have one of the last Hydropulse's in operation ( not at the moment)
The time to replace it is soon..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I might have one also, worked on plenty over the years. Still have the flapper discs around I think too.0
I remember when the 150 came out. I was doing a job for an Acoustic Engineer's home. I suggested the 150, he went for it, I put it in and when I fired that thing up I thought it was going to walk right out of the room. It was very unpleasant.
- 114 Geothermal
