Same old story...failed steamer.
Yet ANOTHER...pictured is the near boiler piping and failed section. Boiler is being removed now. It will be a late night but expect finished pictures.
1
Skimming has begun!0
Check out the time lapse video!
https://www.facebook.com/scullysplumbing/videos/10155149121732899/4 -
How old was the failed boiler and what manufacturer was it?
Very nice new piping - thanks for sharing! You guys work fast!
@Danny Scully what did you use to create the time lapse video?0
Nice!!DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......-1 -
Thanks @Danny Scully. Was it using way too much fresh make-up water? Have you guys talked to the HO about conditioning water with Carbon/RO/IX and use of steamaster or adding of lye? I've had this same exact above the water line looking leak on the end section of WM LGB, on the 7th heating season. A large buildup blister on the inside, opposite side of the leak. We had quite a large water use for 6 seasons, unbeknownst to us until I added a water meter. It was addressed and failed traps were fixed last spring. Shortly after, I noticed larger than normal water use and heard hissing when standing next to the boiler. I wrote of it elsewhere on the Wall.Danny Scully said:Failed and replacement boilers were/are Burnham Independence. A test of the water quality revealed the most likely cause of the failure.
At any rate, I have now implemented manually adding distilled and RO water after the weekly blowdown (we have a condensate return tank with float switch that needs weekly blow-down). I also added the steamaster tablets to raise pH and add some treatment to the water... pH is about 9-10, according to strips - good enough and didn't need to add lye. This regiment seems to be now keeping the chemical composition in check: pH, TDS and Chlorides all within normal range.
In case you want to see the thread about the water quality, here's the link:
http://forum.heatinghelp.com/discussion/161080/water-softener-and-steam-boiler/p2
Great looking job you guys! Wish you were in Cincinnati...0 -
Thanks @miland. It fed close to 200 gallons in 6 years or so (if it was never reset). As I said, the quality of the water is unacceptable, so, we will be introducing Steamaster.1
Yep, and wow - that's a lot of fresh water... glad they are up and running with a new rig, esp. on a day like today. I hope system leaks are eliminated for a long and healthy boiler life.Danny Scully said:Thanks @miland. It fed close to 200 gallons in 6 years or so (if it was never reset). As I said, the quality of the water is unacceptable, so, we will be introducing Steamaster.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
