Nature of the New Steam Beast
HeatingHelp
Administrator Posts: 718
Steam systems ain’t what they used to be, or at least so it would seem to some homeowners. The fact of the matter is that many retrofit steam boilers – under certain conditions – aren’t lasting as long as their predecessors. Naturally, it begs the question, “Why?”
Great points. Thanks for sharing, Dan.
President
HeatingHelp.com0 -
Who will pay for an efficient durable boiler?0
I would... I like my Weil-McClain, don't get me wrong, but I don't expect it to last more than 15 years. The HB Smith which was original to the system was horribly inefficient (it took 5 gallons per hour to do what Cedric happily does on 3) -- but it lasted 40 years, and was till going strong when it was replaced.
Come to think of it, it looked pretty impressive, too...Br. Jamie, osb
Jamie,did you consider keeping HB Smith and improving efficiency with heat recovery?0
I would have -- but that was done before I took over here.jumper said:Jamie,did you consider keeping HB Smith and improving efficiency with heat recovery?
Very helpful article - especially the guidelines for water quality. I'm a new homeowner and had to replace a boiler within 3 months of buying my house. I purchased the Peerless # 63-04L. I called my water company and my pH is 7.5, so in the recommended guidelines; however, I find that this season my automatic feed is running more than last season (Philadelphia suburbs). I had the boiler serviced in early November and I'm up to 59 gallons on my VXT meter. I've checked for leaks and everything is dry. No piping underground. Any thoughts on why so much make up water?
Thanks0 -
Are any of the vents leaking steam? Check to make sure they are closing completely when steam hits them. Also, check all the radiator valves to make sure they are not leaking water or steam. 20 or so gallons a month probably indicates a few vents/valves steaming or leaking. if you are sure you have walked all the piping and have no leaks in the piping (both mains and returns).0
