Tankless water heater pipe size vs performance
doooglasss
Member Posts: 18
I've posted here before and sorry for all the questions, but I'm renovating my house so there are always more. In the past I've had great responses on this forum so I figure I'll come back for more!
I'm about to re-plumb my bathroom and kitchen hot water feeds to a Uponor EP valved manifold - essentially making a central distribution point with a per fixture hot water feed instead of a branched model.
I currently have a Burnham KV74 with side mounted DHW coil. The manual claims the inlets are 3/4" NPT, however, whomever plumbed this setup decided to use 1/2" copper about 4 feet above the boiler. Up until that point there is 3/4" copper supply & return.
I'm wondering if the restriction in flow from 3/4" to 1/2" would be reducing my hot water performance at all?
I know this boiler needs to be replaced for my purposes, but I am trying to work with it for now and prep the home for a boiler/tank swap by running pex in the ceiling before I close it back up with drywall.
You would be losing pressure, and quite possibly some flow because of that, but that's all.Br. Jamie, osb
