How much water should my new weill mc lain boiler use?
sanblas
sanblas Member Posts: 19
New install. Eg75. 6 unit bldg. Indirect hot water tank. New returns, new main vents, new air vents all radiators.
I have a water reader. Boiler is taking in about a gallon or so a day of water, is this normal?
What could cause this? Maybe i have a tiny leak on new undergroung return?
I appreciate any input.
  • BobC
    BobC Member Posts: 5,567
    You probably have a leak somewhere. Check all the piping joints, and all valves and vents. I would be suspicious of any piping that goes underground,
    Bob
    3PSI gauge
    Ironman
    Jamie Hall Member Posts: 27,395
    Bob
    Second that. My now 6 year old WM uses about a quart a day -- max -- in cold weather when it's working hard, and almost nothing otherwise. And I think that's more than it should...
  • sanblas
    Thanks for the input. Will look for the leak
