Polybutylene in space heating (radiant) applications, failures?
Mark Eatherton
Member Posts: 5,874
Wallies, I have a good friend who is undergoing scrutiny regarding a radiant floor heating system. Is anyone here aware of complete tubing failures on a true closed loop hydronic heating system? He's aware of the issues of oxygen impingement. Just wanting to know if anyone has ever documented tubing failure in this type of application.
Thanks in advance for responding.
ME
ME
Oddly enough... never seen a tubing failure. Lots of pix of mudded up components, failed radiators and black ooze.0
No issues that I recall. The acetyl fittings and also the early aluminum crimp rings. They didn't keep tension so well
It was a nice flexible tube and very freeze tolerantBob "hot rod" Rohr
Living the hydronic dream0 -
Only when the bend radius is too small. Then I've seen it crack over time.Bob Boan
Mark,
I have looked long and hard on this one as it is common on home inspection reports.
There where obviously mass failures of over crimped PB fittings that where widely reported. There where also some reports of failed tubing that was heavily chlorinated or exposed to UV. Hardly the tubing's fault.
I have yet to find a single case of tubing failure with PB where the tubing was at fault.In the one case I have personally seen the tubing fail, the failure was caused by a dry fired boiler that flashed to steam. The conditions of the failure where certainly well beyond the design temp and pressure of any tubing.
Dan makes a great summary of the down fall of PB in "Radiant Heating for the Non Engineer installer". Unfortunately my copy of the book has disappeared. Maybe someone can post it as it was awesome.
Ironically the inspection report that I was asked to refute made no mention of the O2 barrier issue which had completely destroyed the boiler. There was just a vague condemnation of the tubing because it was PB...
Albert Einstein1 -
My home has 2300 Sq feet of concrete with PBX (O2 barrier)buried, also a fair amount in wall and under floor on plates. Run CI boiler and blk pipe without HEX for 22 years.
Only problem was some Infloor Manifolds with push in quick connects that started to leak.0 -
There are only a few PB systems around here, and the only problem I have ever had with them is at the manifold as the tubes were connected with compression joints. If the nuts got loose they would leak, but they also had a habit of having the buts crack.
Haven't seen a tubing failure so far.
Rick0 -
Never with the tubing itself, only the "iron stuff" that failed because it wasn't used properly.Steve Minnich0
- 120 Geothermal
- 394 Solar
