Pinhole water leaks on Long Island
  • Ironman
    Ironman Member Posts: 7,859
    "Everything suggests this water is highly corrosive in the context of causing copper pinhole leaks," he said.
    Duh!
    Bob Boan
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,413
    You should see Village Of Garden City...tons of service calls over the years. "They " always say it's from stray elec. Current. Mad Dog
  • EzzyT
    EzzyT Member Posts: 1,377
    There are some towns in my area that the water is so corrosive that pinhole leaks are normal but from the info I've gotten from the water company and from lab testing that the quality of water passes EPA and DEP requirements, it's all left up to the building owners to treat there water.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Jamie Hall Member Posts: 26,842
    And oddly enough, the softest purest water can be the most aggressive...
    hot_rod Member Posts: 26,606
    Water softener that use ion exchange can add to problems. Anything that increases th conductivity of the water may add to corrosion
    Water purveyors are using a lot if different treatment chemicals these days to stay ahead of bacteria issues and concerns
    Recently a wood boiler manufacturer told me of poly phosphates being added in some areas to help keep iron on solution. It creates a sludging problem when heated to hydronic temperatures
    California has pin hole copper issues for many years and would not allow plastics or Pex until fairly recently
    Fix the water or use all non metallic components
    Wonder how the human body will handle all the chemicals the add?
