Re-Piping Needed
gypsy
gypsy Member Posts: 84
Hello Wall, Im looking for a steam Guru who can fix this system in central MA.
  • Paul S_3
    Paul S_3 Member Posts: 1,292
    edited May 2016
    @Charlie from wmass can help you....whats going on with it?
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    Heat out of the radiators when the boiler heats the indirect. Also note the 007 circulator.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
    Steamhead Member Posts: 18,324
    That's a Dunkirk, and as usual some knucklehead reduced the size of the steam outlet. One of these days I'll see one with a full 2-1/2" riser and header, that we didn't repipe, and I won't know how to react......................
    Consulting
    Dave0176gypsy
    The op has been dealing with this for years. Several contractors aside from me have looked at this and all say it is piped correctly.
    cell # 413-841-6726
    gypsy
  • SWEI
    SWEI Member Posts: 7,348
    Nice near-boiler venting job there.
  • KC_Jones
    KC_Jones Member Posts: 5,916
    If Charlie has already looked at it you already have your guru. Just cut him loose on it.
    2014 Weil Mclain EG-40
    gypsy
    It is not as simple as that. But progress is coming.
    cell # 413-841-6726
    gypsy
    edited May 2016
    It's amazing how many contractors are not capable of reading and following a piping diagram. You can't fix stupid.
    Here is the manual, containing the piping diagram:
    http://www.dunkirk.com/sites/default/files/3870.pdf
    Note that it says "Pipe Full Size Same As Boiler Tapping (2-1/2")". It's right there in black and white. What part of that don't they understand?
    Consulting
    gypsy
  • Paul48
    Paul48 Member Posts: 4,469
    Don't you have to open the boiler packet to be able to read that? It's sad..........Intentionally, or unintentionally, it's taking advantage of people. Does every homeowner have to know how their new boiler should be piped? I guess I know the answer to that. I know things, about stuff I never wanted to learn, because every trade has attempted to screw me every time I've tried to pay someone else to do work.
    gypsy
  • AMservices
    AMservices Member Posts: 611
    How contractor's can get by doing whatever they want and leaving all those problems behind for the customer is something I don't understand and never will.
    Every boiler manual I've ever looked at has different specifications on how the manufacturer wants each model piped. Steam piping in these manual usually give a bad, better, best options for the installer to choose, but this just guy just tried his best with his imagination.
    How this contractor dreamed up the placement of those main air vents looks like a nightmare to people that understands steam operations.
    Steam systems can be the greatest heating system to have when it's done right. Low maintenance costs, extremely dependable, balanced, next to nothing for electricity and when it's taken care of, it can last a 100 years.
    If your in side the 495 belt I can help.
    Also take a look at what's possible for the lucky home owners with steam.
    https://drive.google.com/open?id=0B-5hKw5FhaA4RndtYjcxOWFSYWM
    gypsy
  • Danny Scully
    Danny Scully Member Posts: 1,465
    edited May 2016
    A lot of work went into piping that wrong :smiley: I love the drip...connected to the dry return...above the waterline...with a vent
    gypsy
  • Abracadabra
    Abracadabra Member Posts: 1,949
    But... but.. then you need a 2-1/2" threader..
    Home depot doesn't sell those :D
    I have seen dozens of boilers with vents at the headers of boilers. Note they are usually on counter flow systems and in either Worcester County or Hampden County Massachusetts. One side of this house is counterflow the other is parallel flow.
    cell # 413-841-6726
  • ChrisJ
    ChrisJ Member Posts: 17,162
    A bunch off Massachusetts licensed contractors installing boilers wrong eh?
    It's a shame more of them aren't like you.
    Then again, I guess that goes for the whole country.
    Curious, can you thread 2 1/2" ? My threader only goes to 2".
    edited May 2016
    I am able to thread to 6" with a geared threader and to 4" with my larger power threader.
    cell # 413-841-6726
    There is no license currently to install boilers under 5mbtu in Massachusetts. Just for the water and fuels going into it. So the point is we need a hydronic heating license.
    cell # 413-841-6726
    HillySWEIZman
  • ChrisJ
    edited May 2016
    I guess because Diesel, NG and LPG are dangerous but ripping people off isn't.
    An improperly piped steamer is often a fuel hog though..........
    The original idea was if you could pass the test to get the plumbing license you could install a boiler according to the installation manual. We do have sheet metal licensing and oil burner technician certification.
    cell # 413-841-6726
  • ChrisJ
    edited May 2016
    Yeah,
    Sheet metal license comes in handy when installing a package boiler. Especially direct vent ones.
    These guys take 100% assembled boilers, and can't even install them right. Imagine if they had to actually fabricate something!? Maybe the guy can bend him self up a chair using a brake so he can sit his arse down and read the instruction manual first?
    gypsy
    Sheet metal license is for warm air furnaces and metal roofing.
    cell # 413-841-6726
  • ChrisJ
    edited May 2016
    I don't mean to insult anyone but this keeps happening.
    It happens on steamers, hot water boilers and even on forced air furnaces and it's all 100% due to laziness.
    It's not just the lowest bidder either, alleged high quality contractors do botch jobs constantly and there's no excuse.
    Everyone makes mistakes, I make mistakes, I've told you some of them, but these aren't mistakes.
    gypsy
  • ChrisJ
    Does that include modern duct work that is more like pressed fiberglass and flex duct? :)
    I find most of it is the blind leading the blind for generations.
    cell # 413-841-6726
  • unclejohn
    unclejohn Member Posts: 1,833
    looked at a boiler that needed replacing and told the engineer at the school that it had to be re piped because the equalizer tee was either too high or too low. He said that another company had not changed any thing on the other boiler that was identical too this one. So we went and looked at that boiler that was replaced 6 years ago. There was a puddle of water under it. The installation manual was right there on top of the boiler still in the unopened plastic bag. There a reason they give specific measurements like 27" off floor and 24" min from top.
    gypsy
  • Paul48
    Metal roofing? My last job, was repairing and adjusting portable machines that formed standing seam roofing , and gutters. I'd love to know how they qualify you for a license to do metal roofing, when the application is specific to the manufacturer.
    You need to understand how to follow directions.
    cell # 413-841-6726
    gypsyZman
  • ChrisJ
    So then that sheet metal license means you can literally install anything that comes with directions?
    I was joking.
    cell # 413-841-6726
  • ChrisJ
    I was joking.
    Oh.
    Ha, Ha, Ha.
  • gypsy
    edited May 2016
    Thank you everyone, I have a fix lined up.
