What a disaster
Dave0176
Member Posts: 1,178
in Gas Heating
Got a call to service and find out why so little heat. I found this disaster, and no the owner won't replace it. Anyway I had to bleed the loops and found a the extrol tank pissing, so I replaced that, (it isn't even piped properly, in fact the whole boiler isn't piped properly, wrong minimum pipe sizes, pumped to the return). I also thought it was under firing which I was right, I clocked the gas meter and found it burning 425,000 BTU, checked pressure was good, so I replaced the gas valve too, and now we're burning the proper 550,000 BTU. Anyway you can lead a horse to water but..........
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
1
Unbelievable. I think you just adopted a problem child.0
Ya gotta love the switches mounted directly to the pumps.Steve Minnich0
Don't have to label the switches thenStephen Minnich said:Ya gotta love the switches mounted directly to the pumps.
1 -
From the looks of the roll out I wonder if the chimney is pulling a draft...prob not lined.0
I did a combustion test with my testo and everything seemed alright, had good draft. Who knows what shoemaker worked on this thing in the past.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Dave you'll be back there plenty nurturing that disaster.0
- 120 Geothermal
- 169 Indoor-Air Quality
