Wi Fi Thermostats
guardian
Member Posts: 3
So most currant systems carry the "C" or common wire for new wifi set ups. So which is the correct wiring for an older or currant 2 wire oil fired systems. I was told install 2nd transformer remove jumper from R& RC . Connect heat to R & W. Common from new trans to C and power side of trans to RC. This info tech support. Is this Correct? have installed other wi fi set ups but this is first Or test run on an 2 wire oil fired system. This is a hot water bb system single zone cold start.
1
Zman . Where do get a common wire from a Honeywell aquastat L8124A?0
I don't have one in front of me. From the looks of the schematic,I don't think they gave you a terminal or a wire to cut into. You would probably have to solder onto the board.
That was not very nice on Honeywell's part...
If you add a tranformer to the system be sure you wire it to the same 120 circuit as the other one or you can end up 48 volts rather than 24 volts. I knew a guy that did that, it lets all the smoke out. LOL."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
That 48 volts is why they're having you pull the jumper from R-RC. That basically separates the two functions, power to the stat on RC(ooling) & C, R (think RHeat) & W.
Also not getting the 48 volts depends not only on the right circuit, but the right polarity on that circuit as well - if it's backwards you still get 24 + 24 volts...
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
