WM Ultra Series 3 not achieving CH target, DHW production is good
wcs5050
wcs5050 Member Posts: 147
First off, this is all passed from customer since install is not nearby.
Sounds like control kills the burner at 90degF on a 150degF target. No error codes or faults. DHW is operating as it should.
Does anyone know of this control having some quirky behavior?
  • kcopp
    kcopp Member Posts: 4,564
    Is the house warm?
  • Paul48
    Paul48 Member Posts: 4,469
    Is there an outdoor sensor on the system?
  • wcs5050
    House is not warm. OD sensor present. Target never achieved on CH. I feel like one of the sensors... be it OD, supply, return, exhaust has possibly failed.
  • Paul48
    Someone entered 150*, and(incorrectly) expects the boiler to run to that. The house is running ODR, and it is not set correctly. Unless the house is in the Artic circle, there is no way the boiler should be calling for 150*.
  • Zman
    Zman Member Posts: 7,611
    How would you know the correct target temp without knowing what type of radiation?
    I would start by jumping the TT terminals to be sure it is a boiler issues. It could easily be bad contacts in a t-stat or controller. From there, double check all the settings.
    Albert Einstein
  • Paul48
    You're right......I'm sure the t-stat is killing the burner at 90*
  • wcs5050
    edited December 2015
    custy says fan coil blowing cold, and/or TT doing 63degF.
    i'm just going to have to go out there and check the settings. i'm being told no one touched the settings, but I don't believe it. yes, why would it be showing a 150 target right now? just trying to avoid going to the city. maybe dirty air filter on air handler.
    Jamie Hall Member Posts: 26,022
    I hate to say this, but if you're being told that no one touched the settings... the odds are someone touched the settings. Don't blame you for wanting to avoid the trip, though!
  • GW
    GW Member Posts: 4,972
    We service one of those series 3's as well, and we had the exact same thing happen a few weeks ago. We strongly believe someone played with it. Reset the proper settings and all is good. Sent a bill for our efforts (non owner occupied).
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    kcopp
  • Is there any security on the controls, such as a password?--NBC
  • Paul48
    Can you unplug the display? :wink:
  • That would be a good reason to have an Internet-connected boiler, so the responsible party could check the settings from outside.--NBC
  • JohnNY
    JohnNY Member Posts: 3,321
    I've recently bought two Lochinvar Con-X-Us systems for just this reason. You know it's a settings issue. Wouldn't it be nice to be able to fix it from your couch?
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Zman
    I assume sarcasm...
    I would still try to isolate the problem rather than jump to conclusions without all the info.
    Albert Einstein
  • Paul48
    Absolutely..........There is no need to make someone else wrong to be right. Just state your opinion, and maybe I would change mine. There is entirely too much of that going on here, and it's not necessary.
    Zman
  • Zman
    This is something all manufactures could use.
    It is helpful for the owner to be able report error messages and operating conditions. All to often, the owner accidentally changes a setting.
    Albert Einstein
