Snow Stair Detail
Zman
Zman Member Posts: 7,614
Does someone have a detail for snowmelt in stairs they would be willing to share?
It will be 5/8" hepex tubing. I thought I had one saved but am having trouble finding it.
Carl
Albert Einstein
    hot_rod Member Posts: 27,830
    I've always been impressed with Johns snowmelt design and detail at ART in upstate NY.
    He shares about 10 snowmelt jobs at his site.
    http://radiant-design.com/projects.php?type=snowmelt
    I liked the MultiCor method with tube running up and down the stairs.
    I recommend at least 4 tubes across a tread and one close to the nose of the tread as it has two cold surfaces to warm.
    Keeping the tube up in the pour is critical. You want 1- 1-1/2 times the aggregate size above the tube, so at least 1-1/2" of concrete above the tube.
    It takes a lot of careful prep work to get it right, having the plumber work with the concrete form guys is a key to getting it right.
    Steve Minnich
  • Ironman
    Ironman Member Posts: 7,927
    @hot rod
    I love your profile pic. Are you gonna connect warm water to that bed frame?
    Bob Boan
