Megasteam Selection
hvacfreak2
Member Posts: 500
Hey Guys ,
I need to select a Megasteam and would like opinions . My connected load is 431 square feet placing me in the middle of the 396 and the 513. Existing V7 is 1 gph at 140 psi . I'm thinking that the 396 will still be a heck of alot better than what I have but I'm not going to dispute the numbers. Thanks for replies.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
Easyio FG20 Controller
How well insulated are the pipes?0
Everything is 1 inch fiberglass that I can get to. I have some aluminum jacket for everything but I have not got that on yet.hvacfreak
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
The smaller one, the 33% pickup will more than cover the differenceTo learn more about this professional, click here to visit their ad in Find A Contractor.2
The MST396 will be perfect........DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Thanks for the replies.
Question : Pick up factor of 1.33 and 431 sq. ft. gets me to 137 MBH . The MST 396 is rated at 127 MBH DOE . Is this difference acceptable ? The MST 513 is rated at 164 DOE .hvacfreak
You should be fine. The MST 513 is going to put you at almost 20% oversized on rated EDR PLUS the 33% additional pick-up factor. The MST 396 will still leave you close to 20% pick-up factor.0
Thank you very much , 396 it is.hvacfreak
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
