Oil boiler question
njtommy
Member Posts: 1,105
A buddy of mine ask me to install a new oil boiler for him. He's looking at a Crown free port boiler which is a 3 pass boiler and its 87%er.
The other crown oil boiler is just a standard cast iron boiler that is 85-86%.
All costs aside is he really gaining much out of the 3 pass boiler over a traditional cast iron boiler?
Sure. Make the heat lost by combustion scrub off more efficiently by wafting thru a 3 pass, vs. Right up thru a pinner.0
Current boiler does not have a DHW coil in it. He has a indirect tank that will be replaced at the same time. Its a 2,000 sq ft home with 4 zones valve and a large B and G pump. He also wants to go to 4 smaller pumps instead.0
@ hatterasguy
That's what I plained on doing, but he doesn't want to run a single pump any more. I think it's stupid to run 4 pumps. I even told him I could pipe in a second pump for back up and he could just open two valves, but still is set on 4 pumps.0 -
Lol
I tried to tell him the biggest problem he has is that oversized pump.0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
