Proper venting in door for boiler
cyndie
Member Posts: 2
in Gas Heating
I need to replace the door leading to my boiler closet. Need to know the amount of surface that the vent needs to cover. Door would be 30 x 80".
how many btu is the boiler
Is this a fire code door? Does it have fusible links on the openings designed to melt in the event of fire. I am going to assume two openings one at the top one at the bottom. Is that correct?
Does the door to the boiler closet communicate with another room and if so how large is the room. The concern is having adequate air for combustion.0 -
Yup I agree just a plain old louverd door...but then again a pic is always best...never know...This is a smart poster asking for advice...I am glad he did...could be a lifesaver,imagine that a little simple door0
Field controls Cas-4 maybe check out their site will give you good info.Good question.0
- 87.4K THE MAIN WALL
- 122 Chimneys & Flues
- 15.8K Strictly Steam
