POLARIS WATER HEATER
Tim Potter
Member Posts: 273
I want to be proactive, I want to have a plan for if & when the tank goes. I dont want to be scrambling late at night with my boiler guy discussing a plan.
I just purchased a 14 year old condo with the Polaris (PG1034-100-2nv) 34 gal, 100,000 BTU providing DHW & infloor radiant in GYP.
DHW & heat are separated by a flat plate heat exchanger, has a mixing valve to temper DHW, & 2nd mixing valve to limit water temps in the tubing.
600 sq ft condo, top floor, end unit, 9000' elevation FRASER, CO Design day -20*.
Havent had a chance to do a heat loss yet, (tenant occupy till april), but it can't be much.
006 pump to FPHE
007 pump for the 3 loops,
Thank You for any thoughts & input,
Tim
006 pump to FPHE
Tim
Winter Park, CO & Arvada, CO
A small combi boiler like the Bosch GreenStar.Bob Boan
I would use an HTP Phoenix , PH100-55 . There should only be a bit of repipe since it is similarly designed with the exception of modulation . If you are happy with how this has performed and the lifecycle of it you'll be happier knowing the Phoenix will last longer than this one has . Choice is yours , light duty may be better suited in BTU size . Less work and less BTUs than any combi without worrying about cold water sandwich , DHW priority , not enough GPM . Pretty damn close to existing with a boost in efficiency .
http://www.htproducts.com/phoenixwaterheater.html
http://www.htproducts.com/phoenixldwaterheater.html
You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Thank You for the input guys.
What do i need to be aware of, or is there any high failure rate parts that I should have on hand for this unit?
TimWinter Park, CO & Arvada, CO0 -
This may be one of the few cases where a water heater makes sense. Your design day heat loss is probably less than 15k. The typical day would be single digits. They don't make boilers that small.
I think adding outdoor reset controls with a boiler protection feature would give you better comfort and insure that the btu hungry slab does not rob you of a hot shower one day.
You could do that with either a variable speed injection control on the domestic side or a smart mixing valve in place of the one you have."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I agree, you already have a heat exchanger so a simple swap would be the best bet. If it's been working for fourteen years as is just leave it as is.Zman said:This may be one of the few cases where a water heater makes sense. Your design day heat loss is probably less than 15k. The typical day would be single digits. They don't make boilers that small.
You could do that with either a variable speed injection control on the domestic side or a smart mixing valve in place of the one you have.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
