1/4 of an ounce!
ChrisJ
Member Posts: 13,901
Finally installed the 16" WC gauge and fired the system up. The highest I saw was 1/4 of an ounce and that happened after the main vents closed.
youtu.be/N4YiJR-TQg8
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
1
Yeah, but is it still too much?0
But, my threader only goes to 2"?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
Time to buy a Ridgid 161 lolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
LOL!JStar said:Yeah, but is it still too much?
I know what he can do.
1. Take the entire system apart.
2. Clean the insides of all the pipes to make them as smooth as possible.
3. Either polish the inside of the pipes or coat them in a low friction material.
That might reduce the frictional losses enough to reduce your pressure further. Now get to work!0 -
Port and polish a steam system eh?
KC, what pressure are you typically seeing? I know you told me but I can't remember.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Or just send all your pipe to these guys.
http://www.extrudehoneafm.com/0 -
@vaporvac tell Chris about all that wonderful vacuum you have in your system. lol Sorry Chris couldn't resist. Seriously though that is a finely tuned system you have there! Good job!1
Why do you think my gauge also shows vacuum?
Possible future modification perhaps?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Chris, is it truely a vacuum or does the gauge need to be recalibrated? I know my gauge was showing a similar situation (0-3psi gauge) and about once a year I have to recalibrate it. It will show a negative when the boiler has been off for days. Once calibrated it is fine for about a year.0
Hi Fred,Fred said:Chris, is it truely a vacuum or does the gauge need to be recalibrated? I know my gauge was showing a similar situation (0-3psi gauge) and about once a year I have to recalibrate it. It will show a negative when the boiler has been off for days. Once calibrated it is fine for about a year.
I meant the gauge can also indicate vacuum. In my video from the 17F windy night it's showing a positive pressure of around 0.5" to 1" WC. To me it's closer to 0.5" WC average.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
