Main venting question
Dave0176
Member Posts: 1,178
I got about 25' of 2 -1/2" main, then it's reduced down to 2" for the remaining distance of about 35'
How much venting is required for that run, there is only one Gorton No. 1 at the drip elbow tapped for 3/8 pipe??
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
I would do two gortons #20
Forgot to add there is another 25' of 1-1/4" dry return with one Gorton No.1 on the vertical drip. Definitely doesn't seem like enough venting? Thinking maybe three No.2
The other return only returns two run outs and sized with one inch pipe and has one No.1 on its vertical drip.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
