pipe covering
Hollis
Hollis Member Posts: 105
Ok, I have heard you need to cover pipes with SOMETHING. I happen to have a lot of REFLECTIX. You know that aluminum bubble wrap stuff. Is that suitable for using as a pipe wrap? Not sure of the r value and they state something like "equivalent r value" trying to say that the radiant part the stuff comes into play as insulation and not part of the official way of determining such (as I understand the literature) Anyway it seems like good stuff for certain purposes, like placed behind radiators that are on outside walls,..but wondering if its enough for adequate pipe insulation?
P I have enough to double wrap all pipes.
    Jamie Hall Member Posts: 26,919
    I'd be rather wary of it's temperature rating. I don't think it's meant for steam temperatures.
    Not to mention that it really isn't as effective as an inch of fiberglass would be, even double wrapped.
    kcoppZman
  • Hollis
    Hummm good points, the plastic part of the bubble stuff probably not meant for that heat for very long, Thank you
  • SWEI
    SWEI Member Posts: 7,348
    Aquatherm has a listed approval for Reflectix-style insulation. Works quite well on chilled water. I'm somewhat less impressed with the HW performance.
