Can anyone recommend a good book to learn the more complicated wireing for hot water control's?
directshort
Member Posts: 3
There a quite a few good ones out there.
What is your present comfort zone and what do you want to learn?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Well today for example I failed at wireing a secondary zone. It consisted of a peanut relay off off pump relay, taco zv, stat, and fan center for fan coil in garage. So I'm trying to find good detailed info on things to that nature. This setup was originally slaving off another secondary and I was just going to use a transfer and relay off end switch not realizing that I could just use existing fan center. So if I was doing a new install I still wouldn't have done it correctly.0
I really like this one. It changed the way I look at controls.
http://store.heatinghelp.com/product-p/208.htm"If you can't explain it simply, you don't understand it well enough"
Albert Einstein5 -
Looks like a good start for me. Already ordered. Thanks a million.0
Idronics 14 is a good wiring journal. Www.caleffi.us, click on Idronics. It is a downloadable pdfBob "hot rod" Rohr
Living the hydronic dream0 -
Dave Holdorf
Taco, Inc
I have written 33 manuals on all kinds of wiring configurations, contact me at gastc@cox.net or call 401-437-0557 and I will try to help you out.
I also run one week seminars covering all kinds of wiring and control situations with eight of my manuals as part of the course.0 -
Directshort if your not a licensed at what your trying to do, you best check local codes….Dont know what area ur in, but here in Mass., my area, it requires a permit…..0
