friction loss
smklin
smklin Member Posts: 69
I am wondering how much friction loss i have i my heating system.
710' of 2'' pipe
2 2" 45 degree elbows
21 2" 90 degree elbows
and then i have 3 2" close return bends where the water makes a 180 degree turn
  • remodel
    remodel Member Posts: 64
    what
    kind of pipe?  Also what flows rates do you want to look at? Just a guess will help.
  • smklin
    50 GPM
    I HAVE 50< GPM
    BLACK PIPE SCH 40
    EBEBRATT-Ed Member Posts: 19,588
    Resistance
    At 50 gpm I came up with 4.66 ft of head/100 ft for 2" pipe.
    After converting the fitting footage to ft of pipe the total equivalent feet came out to 919 ft including the 710 feet of pipe.
    919 ft @ 4.66/100 ft =42.8' of head. the fitting chart I had showed 8.5 equivalent feet for a 2" screwed 90. This seems high to me.
    What do you guys show for a 2" screwed 90?
  • bob_46
    bob_46 Member Posts: 813
    Ell
    B&G lists 5 equivalent feet for a 2" screwed 90º ell .
  • smklin
    pump
    what pump will work on that
  • Ironman
    Ironman Member Posts: 7,858
    edited February 2014
    Pump Curve
    Go on Taco's web site and use their pump sizing tool.
    I question using 2" for 50 gpm on a hydronic line. Your velocity maybe too high.
    Bob Boan
  • remodel
    pipe velocity
    At 50 gpm you are getting about 5 ft/s.  Might be too fast? If you reduce your velocity your head loss will go down too.
  • SWEI
    SWEI Member Posts: 7,348
    How much flow do you actually need?
    Reducing flow and increasing ∆T will result pretty big wins both for first cost and electrical usage.
    50 GPM = 42.4 feet (say 20ºF ∆T)
    40 GPM = 27.9 feet at 25ºF ∆T
    30 GPM = 16.3 feet at 30ºF ∆T
  • smklin
    < 50 GPM
    I need 50 gpm. IF I COULD GET 60 I PROBABLY WOULD TAKE IT.
  • SWEI
    in order of preference:
    Reduce the GPM requirement (where did that come from, BTW)?  Increase the ∆T, possibly with hydraulic separation and additional pump(s) downstream.
    Replace as much of the run as practical with larger diameter pipe.  Still better to isolate and branch where practical.
    Install a big pump, eat the electric costs -- and be prepared for erosion corrosion.
