Just A Thought
Which would have higher head: both being equal, 1/2" pipe or 3/4" pipe with a short 1/2" restriction? Thanks
  • SWEI
    SWEI Member Posts: 7,342
    All is not equal
    The answer depends on both flow rate and total length.
    Jamie Hall Member Posts: 27,687
    Depends
    on the length of the pipes vs. the length of the restriction -- but if the restriction is definitely short with regard to the length of the pipe, then the half inch will have greater head loss with flow.
  • Rich Davis_2
    Rich Davis_2 Member Posts: 129
    It's for an Air Compressor
    The air compressor has a 3/4" outlet, it's about 15' run to a retractable hose reel with 50' or 3/8" hose. So I guess the question is should I pipe it with 1/2" or 3/4". Thanks
