Taco zone valve control transformer question
Woof
Woof Member Posts: 2
Hi. I'm installing a taco zvc405 zone valve control. I had this transformer mounted on
the wall. I'm guessing I can eliminate this now, right??? Thanks!!!! Happy unhappy turkey day!
  • Weezbo
    Weezbo Member Posts: 6,231
    Sounds good to me. *~//:)
    a couple new receptacles might look good there one could be hot always and one could be switched thru the boiler switch letting you plug in a drop light or small battery charger or cell phone or whatever while working in the area with the boiler on . and run soot devil drills, sawzalls or whatever when it was turned off.
    or put a 4 square blank over the box cap the wires and call it good.
  • Woof
    Thanks Weez
    Thanks Weezbo!! Good idea with the outlet instead of a blank plate.....
  • Ironman
    Ironman Member Posts: 7,947
    Depends
    On how many zone valves you connect and what their total amp draw is. Read the instructions - it's in there.
    Bob Boan
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,876
    Might also be power for your...
    Gas valve/ pump relay :-)
    Don't throw it away until you're sure the boiler fires...
    ME
  • Weezbo
    Woof ,
    Iron man and Mark also are offering up some salient points of interest .. : )
    Most of my installs i use low draw Taco zone valves , and most of our equipment is oil fired ,
    so no problem . however when i did instal a zv406 the other day to tidy up a rat nest of what goes where ?and no one knows,? what zone is what? or where the controls from This thermostat are run ? ...lol
    i too checked the honewells and also found some field zone valves and transformers that did not even have any message to the boiler room or a Tstat to the boiler room for the zone they ran off of and by the way were not piped correctly even for that purpose .... i too check volts and amps ..
    buh i got rid of the transformer stuck on the wall and tweaked in a receptacle .... because my 406 exp with priority has two transformers in it and has the zone valve issue down .
    i also then gave the boiler more info than low limit control off a tri aquastat .
    put it under Zone Valve Management ! lol...
    zv managements a step above turning it off and on for the season : )))
    i tried to tell them OR is the ticket buh the place has things like maybe i am the only one around now who has a clue .. the building was sold by some old timers kids after they passed on and well, lets just say the wiring , plumbing and heating is "Creative "
    no place within 50 feet of the boiler room for an extension cord that sorta stuff.
    drop light fan any hand tools battery charger / gotta go look around this like 100 by 80 basement , there isnt even one by the transformer in the field under a crawl space ..
    in the ceilings i found one : )))
    so forgive my enthusiam for an additional recep check out the amperios and like Mark said gas valve might need require outside transformer ,
    if it does well might consider moving it to the nearest side of the boiler and shorten up the wire providing the low voltage .
    clamp an amp meter around the whole shabang feeding the switch zvc and boiler ,..on a call for heat from all zone valves and the burner at the same time ,
    as you may still have room to spare on the amperage to have the new receptacle as well.
    we wouldn't need to back track if i had given you better information.
    if every thing is fine with the boiler and zone valves and you have no problem then it was a case of luck over draw. ; )
    might not always be lucky is the truth of the matter . so if i caused you extra work that you have had to do as that was not the transformer for the existing zones which i should have asked rather than take the leap of faith it was , i apologize ...for not recognizing the possibility.
    something indeed cautioned my reply and i did consider it before posting it . buh rolled with it anyway...
    i get that more these days , let us know if that is indeed the transformer for the zone valves specifically and that all the t stats and zone valves work off of the zvc 405 ...
    thanks.
    Weezbo.
  • david sweet
    david sweet Member Posts: 7
    Hi,
    The Taco zone valve control (ZVC) has internal transformer(s), so any external transformers are not required and can be removed.
    So now enjoy the long weekend…
