Quick EDR check
68GMC
Member Posts: 36
Just wanting to doublecheck, before I order a new boiler. One pipe steam. I have an IN6 now, on natural gas.
8 rads. Tube type, 7" roughly width. 3 rads 21" tall, I used 2.2 feet per section. 5 rads 26" tall, I used 2.6 feet per section. 3 rads were 16, 20 and 22 sections. 35, 44 and 48 feet, roughly. 5 rads were 8, 8, 9, 11 and 12 sections. 21, 21, 23, 28, and 31 roughly. Comes up around 250 sq. ft. EDR.
I'm looking at purchasing a Burnham IN4, rated for I believe 271 sq., ft. edr. Still over-sized somewhat, but I feel a good compromise.
And I think I'm going to order a semi-pak, minus controls. A knockdown may be cheaper, but I don't think I want to learn how to assemble a boiler from scratch. Unless anyone has anything to contribute to change my mind.
Thanks!
Thanks!
EDR Form
Hi- I've attached a form that will help you on the EDR. You might want to use this sheet to check your other numbers.
- Rod0 -
EDR form
Thank you. I did use the form, and the chart on Frans Rads website. I was hoping someone would chime in and reassure me that I used the right measurements, and used the right rad calculations. It seems too easy, that's all.0
