What's the proper order for oil to gas conversion?
sunlight33
Member Posts: 378
The house I am buying has an oil fired boiler, I want to switch to gas fired boiler, one contractor will remove the underground oil tank, one contractor will install propane tanks, and another will install gas boiler, is this order correct?
p.s. I can afford to not have hot water for a couple of days.
Depends.
If the oil tank is not going to be in the way, I'd have the propane tank first, filled, followed by the boiler, get you up and running, then yank the tank.
Edit: Why the 3 contractors?There was an error rendering this rich post.
who's responsible for installing gas line?
There obviously has to be some kind of gas line to connect from the propane tank to inside the house, who's responsible for this part? The propane company or the boiler contractor?0 -
good question
I have yet to check if the propane provider can also excavate the oil tank. That's what you meant right?0 -
Find a Propane
company who will do it all. Make sure they do a heat loss on the building and will also conduct a combustion test when completed.
How old is the oil boiler? It may be a candidate for a power gas conversion burner.0 -
Well...
I called a number of propane providers in my area and picked the one with the best rate. And for gas boiler, I want a Viessmann, so that explained why I need two contractors to do the job.
As for the age of the current boiler, I am not too sure except the wall on the fire box has cracked.0 -
OK,,,,
when I install a gas system I take care of everything except ordering the tanks...
And most companies will not hang a meter or fill a tank until the system is ready to be started... So this should be taken into consideration..
Here are the questions I have for you...
1st- Are you renting the tanks or buying?
2nd- does the current location of the oil equipment interfere with the placement of the new gas system? {sometimes it doesnt since oil is on the floor and your viessman will be wall hung and oil needs a chimney and your new system will be dv...
3rd- get a good contractor and have a heat loss done.. this is not skippable...0 -
I see
1. Renting the LP tanks
2. I think so because the new boiler will be installed at the exact corner of the room where the current boiler sits.
3. Yes I will let the contractor do it.
From what you said, it looks like the propane tanks should be ordered after the boiler is installed.0 -
boiler
Usually the propane company will run the line to the house. From there the installing contractor would run the propane line from there. It can be cordinated with the contractor and propane company so everything runs smoothly.
James0 -
I would let your heating contractor handle it.
Call your propane co. and get the tanks installed as soon as they can get there, since this is going to take them a few weeks to come out.
I would consider buying your tanks, the propane is cheaper when you own your tanks...
meanwhile work with your contractor getting the system installed,
As others have said, everyone does it different, my LP companies wont fill the tanks until the system is ready to fire....
When I have a customer that is going to be converting and I have to place their system out of service for more than 24 hours, I install a temporary electric hot water tank {I keep a couple at the shop for this, one is in a customers house rite now and has been there since january when their indirect dyed, but they are switching to gas are and waiting for the gas company to install their line...
But I think your contractor will know best the way the local lp companies work....
I would consider buying your tanks...0 -
One very over looked item !
Seems the more I see these the more I see one over looked problem, That's cleaning of the boiler , these need to scrub down and cleaned out, good wire brushing , and checking chambers, or you Will see just how expensive converting will cost.
David0 -
Is this a new system or
just a burner conversion, I may be confused here, I thought it was an entire boiler and the op was scrapping the oil system all together...0 -
The whole shebang
is going.0 -
Good choice
especially for a system you have no history on...
Did you make any decisions on equipment or system type?
I would get 3 quotes and seriously consider buying your tanks {did I say to buy your tanks yet?}0 -
equipment
I want a Vitodens 200 with a new indirect tank. As for propane, I am going to find out later. Right now I just doing some homework while waiting for the mortgage approval.0 -
What's your design day heat loss?
Just curious...0 -
Not sure
Eventually I will get a contractor to calculate the loss. As for now, pray that they will approve my mortgage.0 -
Good luck
Mortgage rates are amazing rite now, there wont be a better time to buy in our lifetimes...0 -
Yes, good luck
and once you have the heat loss be sure the boiler is sized correctly. Minimum firing rate may be a concern.0
