Oil to gas conversion
Nickinnj
Member Posts: 1
in Gas Heating
Hi,
I just bought a two-unit rental property in NJ. The exist on heating is an oil fired forced air furnace. The oil tank has a slight seepage from one side at the bottom - doesn't drip except a few drops when wiped. The tank is almost empty.
I want to convert to gas. I am thinking of a high efficiency furnace instead of a conversion kit to replace with a gas burner.
Any comments on this?
Thanks,
Nick
Thanks,
Nick
Heat
It can be converted depending on a few factors like furnace model, age, and condition. If it were mine, I'd go for a high efficiency replacement with staging or modulation for the best comfort and fuel savings.0 -
Conversion
DON'T the existing furnace as it is NOT certified to be used with natural gas and does not meet minimal efficiency standards. We have a minimum 90% efficiency standards for new equipment. Your savings from the increased efficiency and possibly various subsidies will pay for the new install in a few years.0 -
Price for price you
are better off when it comes to converting oil furnaces to gas to actually install a Modulating/Condensing furnace. You get away from issues with venting as gas furnace can be sidewall vented that saves perhaps having to line the existing chimney.0
