Open loop system maintenance, flush ?
Mor1ce
Mor1ce Member Posts: 1
I just acquired a townhome with a 10-yr. old open loop system with toesters. Stories about the return water mixing back into the system have me wondering what is the best thing to do next, short of replacing the system. Any suggestions, including who might be a good tech to go to?
  • Zman
    Zman Member Posts: 7,611
    Temps
    What temp does your system run at? Low temps are bad. If you run your system above 140 you will be better off.
    Carl
    Albert Einstein
