Open loop system maintenance, flush ?
Mor1ce
Member Posts: 1
I just acquired a townhome with a 10-yr. old open loop system with toesters. Stories about the return water mixing back into the system have me wondering what is the best thing to do next, short of replacing the system. Any suggestions, including who might be a good tech to go to?
Temps
What temp does your system run at? Low temps are bad. If you run your system above 140 you will be better off.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
