Steam Meter
Steve_210
Member Posts: 664
I have been asked to install a steam meter on a job. It is an apt building. I have not even seen it yet. It is low pressure steam ie there is a boiler in the building, it is not City steam. I have never used a steam meter. Does anyone know the pros and cons and possible problems of using a steam meter or do they even exist?
Thank you in advance.
They exist alright
Google or Bing "Steam meters" and you will get a nice listing of sources of information or supply.
You will also find out that on low pressure saturated steam -- our typical less than 2 psi -- that they aren't particularly common... to put it mildly.Br. Jamie, osb
Thanks Jamie
I am waiting for one company to get back to me.
Anybody used these on LP steam0 -
Measuring Steam
You may want to put a water meter on the return and measure the condensate instead.0 -
Interesting
Thanks Ed. Have you ever done this, how well does it work?0 -
Water meter
No, I've never done this. But this is how district steam was billed back in the old days. I saw this in an old heating book.
The only problem I see is the need for sufficient water pressure to operate the meter and a meter that did not inject too much pressure loss. No problem on a pumped return, but you'd have to watch out on gravity returns.0
