Burner output at various gas pressures....
The Steam Whisperer (Formerly Boilerpro)
Member Posts: 834
in Gas Heating
I am looking for a simple chart that shows burner output related to manifold pressure from about 0.7 inch WC up to 3.5 inches WC., in 0.1 inch increments.
RE
Working on a modulating furnace?
I have a chart for pressures 3.0 to 4.0, but no lower than that. I also have a tech book for York modulating furnaces that shows BTUH output per every step of modulation. Could that help?0 -
For what orifice size
are you looking for?
I use a Bryant Gas Orifice Calculator it goes from .5" W.C. up to 15" W.C.it has a catalog number of MP-5706B, it also includes a pipe size calculator on the other side.0 -
That sounds like it will work
I am trying to find out what manifold pressure to dial in on all the oversized boilers I come upon, which allow downfiring. Most of the time I just disconnect the high fire circuit and the boiler is at least on the same planet as the system size for steam. I'll see if I can get that chart.
Thanks Again!There was an error rendering this rich post.
Tim
I to have the slide calculator and it's a great tool. Used it many times.
Mike T.0
- 87K THE MAIN WALL
- 57 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 388 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
