oil to gas
garrison
garrison Member Posts: 1
I have a series 8 HB Smith boiler with a becket burner / f head and a suntec av 7116 pump. What retro fit lp gas burner would i need to switch over. thank you.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    First question
    are you a homeowner? If so this should only be done by a professional who has done many of these conversions.
    The burners that are available can be retrofitted to your boiler. They are Carlin, Midco and others. The pro who you hire will be able to assist you with the decision as to which burner.
