oil to gas
garrison
Member Posts: 1
in Gas Heating
I have a series 8 HB Smith boiler with a becket burner / f head and a suntec av 7116 pump. What retro fit lp gas burner would i need to switch over. thank you.
First question
are you a homeowner? If so this should only be done by a professional who has done many of these conversions.
The burners that are available can be retrofitted to your boiler. They are Carlin, Midco and others. The pro who you hire will be able to assist you with the decision as to which burner.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
