triangle tube solo 110 sensor
polcat1p
polcat1p Member Posts: 28
this came with a prestige IDWH sensor, but i dont know where it goes? i have the 110 and a buderus LT tank, with a 40006 aquastat. thanks
  • patrick linhardt
    patrick linhardt Member Posts: 134
    for use with a TT Smart tank
    The sensor can replace the snap action aquastat on the TT Smart tank. It will then give you the tank temperature on the display and better control of the indirect.
    I'm not sure if it could be used with the Buderus. Maybe someone else has experience.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Try contacting
    Guy Woolard at gwoolard@triangletube.com
