triangle tube solo 110 sensor
polcat1p
Member Posts: 28
in Gas Heating
this came with a prestige IDWH sensor, but i dont know where it goes? i have the 110 and a buderus LT tank, with a 40006 aquastat. thanks
for use with a TT Smart tank
The sensor can replace the snap action aquastat on the TT Smart tank. It will then give you the tank temperature on the display and better control of the indirect.
I'm not sure if it could be used with the Buderus. Maybe someone else has experience.0 -
Try contacting
Guy Woolard at gwoolard@triangletube.com0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
